dc puller
N CASE
03-20-2005 15:34:40
What would happen if you put a d case gear sprocket[for the chain drive] in a dc would be a better puller or just a hot rod ? anybody try it or want to admit to it ?
CASEPOWER
03-20-2005 17:21:36
 Re: dc puller in reply to N CASE, 03-20-2005 15:34:40
I have a CC that pulls at 8 mph in 1st gear with 15,5x38 tires running at 2400 rpm's. Pulls around 11mph in second.
L.Lamp
03-20-2005 20:34:01
 Re: dc puller in reply to CASEPOWER, 03-20-2005 17:21:36
I have a regular old '52DC3 that someone put DI sprocket in and it does 20mph in 4th and around 8mph in 3rd at stock rpm. This is not a pulling tractor.
DC DENNIS
03-21-2005 07:22:31
 Re: dc puller in reply to L.Lamp, 03-20-2005 20:34:01
I PUT DO SPROCKETS 34 TOOTH I BELEVE, IN MY 51 DC, TO GET IT FASTER IN LOW GEAR FOR THE 3.5 MPH CLASS, WOORKS JUST FINE FOR ME,4500 # CLASS STILL HAVE ENOUGH POWER TO SPIN TIRES, IF YOU GO THROUGH ALL THAT WORK YOU MIGHT THINK ABOUT CHANGING THE AXLES,AND HOUSINGS
AND REMOVE SOME WEIGHT RIGHT AWAY, I DID AND AN NOT SORRY, AN RUNNING 15.5 38, AND NOW AM ABLE TO ADD SOME WEIGHT ON REAR, AM INTERESTED IN ANY IDEAS ON PULLING THE DC CASE DC DENNIS
