vac engine
BrianVAC
03-19-2005 16:38:59
Help please?
I have a vac, in the parts book it shows 2 crankshaft thrush washers with three brass pins,
are both washers out side the block or one inside one out side the block?
Brian VAC
04-09-2005 06:02:47
 Re: vac engine in reply to BrianVAC, 03-19-2005 16:38:59
I hvae a 1947 VAC case I am going to rebuild the engine, need to find a manual for a giude,
is there one just for vac the engine.
Brian VAC
04-04-2005 17:04:53
Joe:
will send me a picture of the cover of the book,
so I can find the book for the rebuild, thanks.
Joe (Wa)
03-19-2005 18:48:58
Brian, I can't be certain this is good advice, I've only done the '50's VAC. Seems to me there was only 2 pins but I am probably wrong on that.
The inner thrust washer is installed between the crank throw and the forward bearing. The chamfered side of the thrust washer faces toward the rear of the engine.
The link is mj's web site. He has posted a VA manual. Click on the link and scroll down to page
47 (G2 M-1), double click on the image to enlarge.
Joe
