Case 530 hoe- shuttle gear
rwg
03-18-2005 07:28:31
I have a 530 backhoe with a shuttle shift. It will not shift into reverse. Forward and neutral are fine. What am I getting into with repairs?
Rwg
Larry from Iowa
03-27-2005 18:37:03
 Re: Case 530 hoe- shuttle gear in reply to rwg, 03-18-2005 07:28:31
My 530 did that a few years ago and when I took the cover off the top I finally noticed a set screw on the slide shaft missing and so I moved the shift fork back over the indent hole and replaced the screw. Lucked out that time. The shaft was galled just enough from the screw coming loose that the shifter stuck on the shaft.
Larry from Iowa
Turf
03-19-2005 08:51:31
Rwg, I have a 530CK that developed the same problem you have!!! It goes into forward and nuetral but won"t physically go into reverse.I haven"t taken my cover off yet to look.Please,please PLEASE reply to me if you find out what it may be.I have books on the machine but it doesn"t show much.Lever is on the left...I can fell gears coming to a gentle stop with light presure but won"t move back.Was going forward and back then wouldn"t.Thanx Dale
wayne2
03-18-2005 20:54:35
I'm pretty sure dennis wants you to pull tranyshifter cover and look.
Dennis/Ohio
03-18-2005 17:40:59
More info?
Shifter moves to reverse position?
Shifter stops and won"t move to reverse position?
Pull the cover first and inspect shift forks etc. If its in the gears, you"ll be splitting tractor. I think I"d remove the hoe first and roll the rear to split. Also this will be the time to replace the shaft seal between the gear boxes (torque tube) and final drive.
rwg
03-18-2005 19:24:40
 Re: Case 530 hoe- shuttle gear in reply to Dennis/Ohio, 03-18-2005 17:40:59
The lever is on the left side. It will move to forward and move into neutral, but the lever won't move to the reverse position. It doesn't grind. It just won't go any further. I looked for a cover to get to the gears, but haven't found one. I can get to the trans. and the clutch housing. That's why I figure I will have to split it.
Dennis/Ohio
03-19-2005 03:11:27
 Re: Case 530 hoe- shuttle gear in reply to rwg, 03-18-2005 19:24:40
I restored a dry clutch model. Thats what I'm familar with but I think the Case-o-Matic used same shuttle/dual-range gear box.
Yes I wanted you to remove the shifter cover. Remove battery, put shifters in neutral, remove bolts & cover. You'll probably see what the problem is.
my email is not blocked, if I can help.
Dennis..... ..
DavidF
07-14-2005 22:05:10
 Re: Case 530 hoe- shuttle gear in reply to Dennis/Ohio, 03-19-2005 03:11:27
Im having an issue with the shuttle shifter. It grinds horribly and sometimes will go forward or reverse, but most of the time it moves the tractor a bit then starts grinding badly. any ideas?
