Generator Light
Mighty
03-18-2005 05:29:22
I wonder if someone could help me with a wiring problem. I cannot seem to locate a wiring diagram that shows how a generator light should be wired on a 441. The parts manual shows it generally wired to the voltage regulator and ignition switch. Is that right, and if so, which terminal on the regulator and which terminal on the switch.
JSTPA
03-18-2005 06:35:00
 Re: Generator Light in reply to Mighty, 03-18-2005 05:29:22
Mighty,
Normally the light wire would be hooked to the armature at the regulator, I can't help you with the switch though, alot of times they're hooked to the assecory(sp) on the switch in a gas engine vehicle. I'm not familiar with your tractor , but on cars that's how they usually did it.
JSTPA
CNJ152
03-18-2005 16:15:26
 Re: Generator Light in reply to JSTPA, 03-18-2005 06:35:00
It will attch to switched voltage at the switch
