david brown case 1290 info
matt lansing
03-17-2005 10:44:16
I just purchased this tractor and was wondering more about it. How much hp, year, how many, part aviablity, and was it a wise investment? It is in pretty rough shape but the motor runs great with low hours, there are stripped gears in the trany that I need to replace, and then I plan on finding tin work, and front end parts to complete the fix up process. I have the # of the tractor here Case 1290 /10 serial # 11053576. Any help would be great.
Does anyone know if any other tractor trannies would fit right in?? Maybe a 990?
Matt
Thad
03-17-2005 18:41:37
 Re: david brown case 1290 info in reply to matt lansing, 03-17-2005 10:44:16
The gears from the 990 might be the same. As far as a drop in tranny a 1390 would be the same. I have salvaged lots of those type tractors. If you cant find what you need give me a call and i will try to help. Thad 417 498 6571
kyhayman
03-17-2005 12:37:25
I think a 1290 will in and out with a later model 990 on the transmission. Need to change the top cover for the side shifters on the 1290 (or keep the centered 990 ones which work better).
