Case 441 loss of engine power
C Spiek
03-17-2005 05:53:59
My Case 441 (gas) has suffered a loss of engine power over the winter. It was functioning ok when I plowed snow in January. However this spring it will start right up but the engine lacks power. It can barely pull itself up a small incline. It will also misfire under any engine load. No water in the oil or excessive smoke from the exhaust. Could this be a timing or other problem with the distributor (such as point, etc.)
Anyone with advise on this problem please let me know what you think.
Klyde
03-17-2005 09:39:29
 Re: Case 441 loss of engine power in reply to C Spiek, 03-17-2005 05:53:59
Yup, sounds like your points have closed up. Check the gap and if they have make sure the lobes are clean and smooth. Cheap points witha plastic lobe rider wear down fast if there is any rust. Look for points with phnolic(sp) lobe rider, and don;t forget a dab of grease.
Wayne J
03-17-2005 10:50:25
 Re: Case 441 loss of engine power in reply to Klyde, 03-17-2005 09:39:29
Also check for moisture in the dist. cap. remove the spark plugs and check to see if one or more did not get filed ??? wayne j
Doc Larry
03-17-2005 18:42:38
 Re: Case 441 loss of engine power in reply to Wayne J, 03-17-2005 10:50:25
You might also check for water in the carburetor and fuel tank.
