Parts needed...52 VAI .....ctext
Gregg in ohio
03-16-2005 11:52:40
Looking for a gas cap and a brake return spring that goes across the shoes in the drum...got it jury rigged and napa could not find one to match..soooo..and i did put in a new 6 VOLT battery in the old girl today..last one lasted 2.5 yrs..that should do it....and anyone ever made a weight box for the front?? what did you use..need some front end weight..bush hog and blade is to heavy..loose my steering...thanks gregg in ohio
C. Amick
03-18-2005 09:52:35
 Re: Parts needed...52 VAI .....ctext in reply to Gregg in ohio, 03-16-2005 11:52:40
I think you can still get gas caps from Case/IH. If you know the measurements of the spring you need, check on McMaster Carr's web site. The last time I needed a brake spring, that's where I got it. The only bad part is that you may not be able to buy only one.
