change over from eagle hitch to draft-o-matic
Mighty
03-16-2005 03:26:16
Can anyone tell me what year, or better yet what serial number, marked the change from the eagle hitch to the draft-o-matic units in the 430-530 series.
I am trying to narrow the window of possible serial numbers for my 430. A former owner drilled a hole in the instrument panel where the plate used to be, and the engine has been changed, so determining an actual number is not likely.
However, I do know it is earlier than serial number 8262800. Based on the serial number chart on this site, that puts it earlier than mid-1965. If I can find when the draft-o-matics started, that would give me the earliest possible date/serial number.
Joe
Old Eb
03-16-2005 08:33:43
 Re: change over from eagle hitch to draft-o-matic in reply to Mighty, 03-16-2005 03:26:16
Old Abe's News Summer 1997 issue had a story on the 430-530-630 tractors and it says that the last Eagle Hitch was built 2/22/63 and was SN 8214360. Doesn't say what model that SN was. Tractors built during 1963 started with SN 8208001 and finished with SN 8229000. Hope this helps.
third party image
Mighty
03-16-2005 10:52:43
 Re: change over from eagle hitch to draft-o-matic in reply to Old Eb, 03-16-2005 08:33:43
It does help...thanks a million
