Post Hole Auger for 1945 VAC
Cash's Case
03-15-2005 15:47:43
I'm looking to buy a post hole auger for my 1945 VAC with wide front end. Any suggestions as to sources would be appreciated. It has an old aftermarket class 1 hitch with hydraulic lift. Does the old PTO require any special consideration?
mj
03-16-2005 19:37:56
 Re: Post Hole Auger for 1945 VAC in reply to Cash's Case, 03-15-2005 15:47:43
I"ve drilled a whole lot of holes with a "Worksaver" (Italy) digger on my "48 VAC AdjWF and never had a problem even with a 12" auger in Mancos shale but I don"t "horse" machinery either.
Cash's Case
03-17-2005 10:53:27
 Re: Post Hole Auger for 1945 VAC in reply to mj, 03-16-2005 19:37:56
Thank you for your response.
Joe (Wa)
03-15-2005 17:29:10
The later VAC's are notorious for weak pto gears, don't know about yours.
Joe
Cash's Case
03-17-2005 10:57:26
 Re: Post Hole Auger for 1945 VAC in reply to Joe (Wa), 03-15-2005 17:29:10
Hope mine is an earlier version!
