Case vai 12 volt conversion
Gregg in ohio
03-14-2005 19:16:30
who sells the conversion for this model 52 VAI..6v batt is dead and i really dont want to buy another one...would really like the 12v conversion...could make the brackets but getting lazy and old...thanks gregg
John Saeli
03-15-2005 04:38:15
 Re: Case vai 12 volt conversion in reply to Gregg in ohio, 03-14-2005 19:16:30
Hey Gregg: A new 12V will go dead someday also. A New Group 1 6V with 625CCA @ 0 degrees F. will do a good job. Cables must be at least 1 Guage, and ends clean. Clean, solid connections. Your flywheel will last longer also.
Gregg in ohio
03-15-2005 06:20:05
 yeah i know...c text in reply to John Saeli, 03-15-2005 04:38:15
but you know everyone says convert it to 12 v..and the traactor never did start hard with the 6v..even in the winter..its just i have a 12 v batt in the shop and the 6 v is 3 yrs old and dead....i remember i used a 8 volt in my old h..it needed it..maybe she will stay a 6volter...thenks gregg
F-I-T
03-15-2005 08:57:24
 Re: yeah i know...c text in reply to Gregg in ohio, 03-15-2005 06:20:05
third party image
My VAC starts great on her new 1,000 CCA Optima 6 volt. I have two now, one in my JD 70 Diesel. Clean up the starter, give it a good ground, and impress your friends with your 6 volt system.
Frank
John Saeli
03-15-2005 10:29:30
 Re: yeah i know...c text in reply to F-I-T, 03-15-2005 08:57:24
Hey Frank: Never saw one. What are the diminsions?
F-I-T
03-15-2005 10:55:37
 Re: yeah i know...c text in reply to John Saeli, 03-15-2005 10:29:30
The best place to read about them is on the Optima site.
Also, they are a gel-cell, spiral wound, maintenance free unit that you can mount upside down if you want. There is only one size in 6 volts.
No more drippy, oozing 6 volters for me.
Wayne J
03-15-2005 10:14:02
i did not know they made a 1000 cca optima 6 volt battery. on any 6 volt tractor converting to 12 is last option. i wood have starter checked, make sure cables are heavy gage 6 volt cable with good ends. I think that 1000 battery is a bit overkill but it auto get it started. next does it charge????? Wayne J
F-I-T
03-15-2005 10:57:00
 Re: yeah i know...c text in reply to Wayne J, 03-15-2005 10:14:02
Well, they only make the 6 volt unit in one size, but it does a nice job. I'm sure that 1,000 CCA at 10 below would not be turned down.
I like the maintenance free aspect.
Frank
