David Brown 990 water pump
Mark (MA)
03-14-2005 06:46:36
Noticed some antifreeze leaking the other day,thought it was a hose. Then while plowing some snow, I heard an awful noise from the front. Jumped off to see the fan wobbling and then seize as I shut it off. Am I correct in assuming the water pump is gone? There appears to be some antifreeze trickling from it now. How difficult is it to change this? Also does anyone have a part # for the water pump? It is a 990A selectomatic serial # 824534/S and engine serial # is 449001 23292.
Any help would be greatly appreciated. Thanks.
Arthur
03-14-2005 08:43:47
 Re: David Brown 990 water pump in reply to Mark (MA), 03-14-2005 06:46:36
Hey Mark....'Bout the only place to get parts for a D B, in New England would be from Frost Farm service in Greenville NH Phone # 603-878-2384. Its right on Rt 123. Where are you from? I'm in Bellingham.
Mark (MA)
03-14-2005 08:54:38
 Re: David Brown 990 water pump in reply to Arthur, 03-14-2005 08:43:47
Ok thanks for that info. I am in Orange, Massachusetts. I have a couple of web sites I've found that I can order parts online from, but I just want to be sure of the part # before I order it.
Elmer
03-15-2005 03:53:21
 Re: David Brown 990 water pump in reply to Mark (MA), 03-14-2005 08:54:38
I should have one of those waterpumps in stock
