930 Diesel Hyraulic Leak
Ron Lee
03-14-2005 06:40:04
I have hyraulic fluid leaking from the PTO shaft seal. Is this difficult to fix? There are three refill caps...one on top of the housing near the seat and two others on the lower left side. Are these separate compartments or will all leak out of the PTO seal??
Thanks for any help.
Ron
Ron Lee
03-14-2005 07:37:28
 Re: 930 Diesel Hyraulic Leak in reply to Ron Lee, 03-14-2005 06:40:04
One other question (not to sound dumb) but do the three re-fill caps take the same hyrualic fluid??
Jim B
03-14-2005 10:58:18
 Re: 930 Diesel Hyraulic Leak in reply to Ron Lee, 03-14-2005 07:37:28
Ron, On my 930 Diesel, 8 Speed, the single fill point for the Transmission and Hydrulic system is at the rear, left side near the 3-point upper link pivot point. It is capped by the breather with the dipstick attached. My owners manual says 17 gallons capacity of Case TCH (Transmission-Clutch-Hydrulic). The PTO system is within the transmission housing. I've never changed a seal on the PTO shaft but it can't be that difficult considering the shaft itself with bearing & housing looks to remove from the rear.
