Case 1816C - Total Loss of Power When Engaging Dr
AVG
03-12-2005 09:26:47
Can anyone give me a hint regarding this problem? Whenever engaging the drive lever, I experience almost a total loss of power, resulting in the Onan engine stalling out. I had both drive pumps rebuilt, which did not help. The motor seems to run fine when drives not engaged...can it be the points? Just before experiencing the loss of power when using the maching (to move snow), I heard a loud bang. Not sure if engine related. Could there be a restriction of the hydraulic fluid somewhere in the system? The gauge near the hydraulic filter shoots up to the red as well (even though I replaced the filter). HELP!!!
Thanks.
case to a gehl man
11-28-2005 11:07:04
 Re: Case 1816C - Total Loss of Power When Engagin in reply to AVG, 03-12-2005 09:26:47
I had an old 1816 years ago and i had the Tecumseh engine with the electric clutch. Not sure if that is what you have but there were times where i would engage it and it would die. Sometimes if the clutch was worn it would do it or if it was very cold when starting it would take several times of engaging and disengaging for a few seconds until it was able to stay in gear and not die. It also took several minutes for the hydraulic steering pumps to warm up as well. I'd have the clutch looked at because it should drive both the hydraulics and steering.
