Ground on Magneto
rockcricker
01-10-2006 19:48:51
I have a 48 SC and was wondering how to hook the ground up to the switch? My switch has two places on it. Thanks for any help.
Glen in TX
01-11-2006 22:06:15
 Re: Ground on Magneto in reply to rockcricker, 01-10-2006 19:48:51
I don't know what kind of switch you are using but make sure the terminal you hook it too will ground the mag to kill in in a off position. Also do NOT ever hook a mag to battery voltage or damage to the mag will occur.
old
01-10-2006 21:24:58
Sort of depends on the switch. Since you are wanting it to ground the mag to stop the engine, you can hook it up to either post, then run a wire from the other one to ground. Then when you turn/pull/push which ever it does to turn it on the engine shoud die.
