What engines will fit?
New to Case
03-11-2005 17:12:02
Like I said in a earlier post my grandfather is giving me a 1948 Case SI that has sat for more than 20 years and i fuigure that i will need to rebuild the engine compontents in it. I was wondering what other Case engines from other tractors engines will fit in it because I might be able to find a complete runnig engine cheaper than buying parts for the one in it now. SO if anyone can tell me if a diffrent tractor engine will fit it will be greatly apprecitated. Thanks
Scott KY
03-11-2005 18:59:17
 Re: What engines will fit? in reply to New to Case, 03-11-2005 17:12:02
The only problem with bolting up another engine is the tractor serial # stamped into the block will not match. If you are not trying to fix the tractor up as original that won't matter.
Camboted
03-11-2005 17:25:10
Any of the "S" model engines should bolt in. The most common is the SC. The engine was also used as an industrial staitionary engine and in the SP-9 Case combine. Other than that I don't know of any other applications. Maybe someone else does? The good news is there are a lot of junked out SC's around.
