Which kind of coil does a Case 200 take?
emilzatopek
03-11-2005 11:41:49
Some coils are designed to have an external resistor in series, others (I believe) have an internal resistance. Which type of coil does the Case 200 take?
Dennis/Ohio
03-13-2005 18:42:47
 Re: Which kind of coil does a Case 200 take? in reply to emilzatopek, 03-11-2005 11:41:49
I think the main thing is you use a condensor that matches the coil you use for point life.
My parts book shows 6 volt coil part# G44810 Condensor #A8370 for auto-Lite distributor
Condensor #1869704 for Delco distributor
mj
03-11-2005 16:30:25
Does your 200 have a resistor in place? Is your 200 a 12v system? If the answer to both is 'YES' then you need a plain-vanilla coil off of anything as long as it's not marked 'No Resistor Needed'. If it's 12v but there is no resistor evident then you can install a resistor (Chrysler preferrred for original 6v system coils) and a plain-vanilla coil off of anything OR a coil that's marked 'No Resistor Needed'. If it's 6v then any coil besides one marked 'No Resistor Needed' will work without adding a resistor..... .Roger???? Additionally: Do a YTmag archive search for '12v conversion' to get a grip on why a resistor is used in 12v systems and not in 6v systems.
