Attn John Saeli
J Kelnhofer
03-10-2005 18:31:37
Maybe that engine is tight bacause I have the wrong size bearings. I was quite sure they were correct though because there were no markings on the old bearings that specified what size they were, just 77 probably for clevite 77, and a part number. The mechanics at the case dealer said that it meant that they were standard size. So without grinding crankshaft, I ordered and put in standard bearings. Is there a way I can back track the part number as to see what size it is? Or if it is right why would the rings be tight? Josh K
John Saeli
03-11-2005 04:46:08
 Re: Attn John Saeli in reply to J Kelnhofer, 03-10-2005 18:31:37
If you could post that number, we could try. Did you put the right Rod Caps on the corrosponding Rods? Are they the correst way? Did you change the Mains? Are they in order? Did you lube everything when assembling? The rings could be tight because the end gap was less than spec. Did you clean out the Ring Grooves on the piston? Keep us posted & we'll get it figured out.
Josh Kelnhofer
03-11-2005 13:39:58
 Re: Attn John Saeli in reply to John Saeli, 03-11-2005 04:46:08
I put the same caps onthe the same rods, and the same pistons went back in the same sleeves. I Had the pistons blasted and I cleaned out grooves. I used clevite 77 engine assembly grease on bearings and coated the pistons and sleeves in 30 weight oil. And no the crankshaft was not even out. The number on the bearings is A-21057. Josh
John Saeli
03-11-2005 18:02:37
 Re: Attn John Saeli in reply to Josh Kelnhofer, 03-11-2005 13:39:58
Hey Josh: I can't find that number. The only way it would be tight is if you used undersize Brgs. & you used Stds. Did you do anything with the Mains? We still don't know about Ring End Gap. Pull the starter out and see how hard the engine turns over with a bar on the flywheel. Keep us posted.
J Kelnhofer
03-12-2005 06:48:11
 Re: Attn John Saeli in reply to John Saeli, 03-11-2005 18:02:37
I did nothing with the mains and never checked for ring end gap, but don't know why they would fit too big. I'll try the flywheel thing. I put a wrench on the crankshaft pulley though and could not get it to move, but I also did not have much room to work with. I'll post back this evening probably. Thanks
John Saeli
03-13-2005 04:45:35
 Re: Attn John Saeli in reply to J Kelnhofer, 03-12-2005 06:48:11
Hey J. What'd you find out? I happened to think later, Was the Starter locked in somehow?
