vac-14
ky ted
03-10-2005 18:22:53
am looking at a 1954 vac-14 a little on the rough side dont think it runs but what would be a fair price. thanks ted
barrett
03-12-2005 16:18:55
 Re: vac-14 in reply to ky ted, 03-10-2005 18:22:53
I have a vac-13 with the wide front end and the eagle hitch. Should I consider it to be worth the same as the 14 being discussed? It also ran 3 to 4 years ago, but has not been started since. It is not locked up. Thanks
Jerry W
03-12-2005 19:26:03
 Re: vac-14 in reply to barrett, 03-12-2005 16:18:55
I would think the value between a VAC13 and a VAC14 would be about the same in like condition. In my area most late VAC are 14's but I do not know how they compare in production numbers or if that affects value.
Jerry
ky ted
03-11-2005 07:51:58
what would the 49 vac be worth it has no fenders but every thing else is ok.
Dug G.
03-11-2005 06:50:50
I"d say $700 at least, if it is not stuck and mostly complete. Running ones around SW ohio are going from $1000-1500 range over the past year. If you have any questions, feel fre to contact me, e-mail unlocked.
ky ted
03-11-2005 04:28:54
it does have a wide front and eagle hitch, would post a picture but dont have a camera. going to look at it today and see if it is stuck thanks for the help. he also has a 1949 vac narrow front and eagle hitch that does run good tin but no fenders.
Arthur
03-11-2005 03:49:06
It depends on how good the tires are. A non-running vac-14 wide front w/ eagle hitch with good tires I would probaly give in the neiborhood of $3-400. If it's not running, you have no way to check the other sub-systems. (the tranny,rear end,eagle hitch,and hyd. sys. ect)Keep in mind, running ones sell for around $800-1000
Arthur
03-11-2005 03:45:28
Jerry W
03-10-2005 20:54:30
How about a picture. WIde front, Eagle hitch?
Jerry
