Any ideas?
DRD
03-10-2005 15:50:26
Here's the story. I'm Overhauling a uncles SC. Found out that block had 4 cracks. Had it brazed and cracked again by #1 piston from top to bottom through Sleeve Seal. (NOT good). Anyway I got another block and put both the crank, bearings and bearing caps from cracked block into new block. After tightening caps I can't turn the crank. The strange thing is if I check the Bearing clearence with Plasti-gauge it will not crush it to give me a measurement. What is going on? Yes I have cleaned bearing surface top bottom and sides, and yes crank did turn free in cracked block.
Thanks for any ideas, DRD
C. Amick
03-11-2005 05:25:09
 Re: Any ideas? in reply to DRD, 03-10-2005 15:50:26
You can't switch main bearing caps from one block to another. Also make sure you turn them the same way they came off. The main bearing journals are bored after the block is cast. The line boring machine doesn't get set the same for each block.
Don L.
03-10-2005 16:21:24
Use the original bearing caps from the replacement block. Your line bore is off.
Don L.
03-10-2005 16:12:46
Use the original bearing caps.
Don L.
DRD
03-11-2005 12:13:15
 Re: Any ideas? in reply to Don L., 03-10-2005 16:12:46
Thanks for the help! Switched caps and crank turns very nice.
Thanks Again, DRD
