case 2394 powershift still fouled-hey caseman ?
benwhi
03-10-2005 04:17:49
i used the wrong model numbers in an earlier post but still am having problems . i replaced the sigmatron board and pulled and cleaned the solenoids and check activations as per the i&t manuel,they are correctbut now with the fuse in or out the engine binds up as soon as the engine cranks and runs about 1 and 1/2 seconds
John Saeli
03-10-2005 04:52:58
 Re: case 2394 powershift still fouled-hey caseman in reply to benwhi, 03-10-2005 04:17:49
Hey Ben: Is there a difference whether you have your foot on the clutch or not? In cold weather, I have to have my foot off the clutch on 1st start-up. Then I have to let it warm up.
benwhi
03-10-2005 18:12:00
 Re: case 2394 powershift still fouled-hey caseman in reply to John Saeli, 03-10-2005 04:52:58
john,thanks for the reply.if you depress the clutch the engine binds up. after the clutch pressures up it binds the engine up and stalls it and then it takes 15 or 20 min. to be able to restart the engine.i rechecked the solenoids timing again and on the 12 speed per the i&t shop manuel only two solenoids are hot or active at a time. i have three when in low or 1st range on the power shift selector.i checked the power shift selector switch and in all other ranges 3 hot leads in and two hot leads out.i checked with the dealer here and that switch is $437.00 i really want to be sure that is it before i replace it.i'm really stumped. thanks, Bennie
