580k Rebuilt Head and Water In Oil HELP!!!!!!!
Bullstuff
03-09-2005 16:48:10
Hello,
I am working on a 580k Backhoe/Loader. I picked up halfway throught the job, which makes things 10 times harder. They had water in the oil, so took off the head and sent it off. Had it welded and it came back. I proceeded to reinstall it. started up beatifully and sounded great. I checked the oil, WHITE!!! I guessed maybee there was some water left over from the engine not being covered well while being fixed, so I changed oil and started again. The dang thing is losing about a half gallon of antifreeze in about 10 minutes. I am stumped. Does anyone have any ideas to look at before tearing it down to see if it needs to be sleeved? I appreciate any help and say thanks in advance.
Bullstuff
Butch/ OH
03-10-2005 18:28:56
 Re: 580k Rebuilt Head and Water In Oil HELP!!!!!!! in reply to Bullstuff, 03-09-2005 16:48:10
If you truly have a 580K and not a 580CK it will have a Cummins engine and it has no sleeves. It does, however, have an engine oil cooler which could leak. You might want to check that.
bullstuff
03-11-2005 04:19:32
 Re: 580k Rebuilt Head and Water In Oil HELP!!!!!!! in reply to Butch/ OH, 03-10-2005 18:28:56
Butch,
It is the 580k, and I will check the oil cooler today. Thanks.
bullstuff
03-10-2005 16:42:19
hmmmm. So nobody knows???
J Kelnhofer
03-10-2005 18:18:00
 Re: 580k Rebuilt Head and Water In Oil HELP!!!!!!! in reply to bullstuff, 03-10-2005 16:42:19
I'm no expert, but probably O rings on the sleeves if that engines has wet sleeves. The old o rings on my 930's engine did not leak, but I replaced them and they were quite brittle and dry.
