Case rims
Rubber Duck
03-08-2005 19:37:48
Still looking for 26in. rims for model D
r aiken
03-15-2005 03:05:15
 Re: Case rims in reply to Rubber Duck, 03-08-2005 19:37:48
I made a rim for my 40 so. Get a 26 inch wheel off a small combine {jd45, gleaner e, ect}. Cut out the center, grind smooth, weld on slip block, paint, and you are ready to go.
Don L.
03-09-2005 11:31:32
My email is open. Don L.
Mathias NY
03-09-2005 04:47:53
I spent several months looking for a replacement 26" rim for my DO last fall. I gave up and made several patches, largest being 4"x10". I cleaned up the rust, braized them to the inside of the rim, then used some bondo to cover any sharp edges. I was fortunate in that the edge of the rim was still good, all I needed to do was to support the inner tube.
Miller tire offers replacement 26" rims, but they are not a deem dish rim. You would have cut the center ridge out of your existing rim and weld it into the new one.
Good luck.
Rubber Duck
03-09-2005 07:04:44
 Re: Case rims in reply to Mathias NY, 03-09-2005 04:47:53
Mathias,thanks for the reply. R.Duck
John Saeli
03-09-2005 04:39:19
Hey Rubber Duck: Where you located?
Rubber Duck
03-09-2005 07:14:43
 Re: Case rims in reply to John Saeli, 03-09-2005 04:39:19
John,I'm in the Phx. Az. area.
John Saeli
03-09-2005 19:10:42
 Re: Case rims in reply to Rubber Duck, 03-09-2005 07:14:43
I can get rims, but we're quite a distance from each other. Freight would be a killer.
Rubber Duck
03-10-2005 08:04:36
 Re: Case rims in reply to John Saeli, 03-09-2005 19:10:42
Just how far? I'll do some checking on freight.
John Saeli
03-10-2005 16:43:37
 Re: Case rims in reply to Rubber Duck, 03-10-2005 08:04:36
Hey Rubber Duck: We're here in Upstate New York. 1/2 way between Rochester & Syracuse, about 15 miles South of I-90.
Rubber Duck
03-19-2005 08:17:14
 Re: Case rims in reply to John Saeli, 03-10-2005 16:43:37
Your right freight wood be a killer. Give me a price on 2 26in. by 12in. rims and I'll check on freight. Thanks
