DCTom or Don L Help
Jerry Thomas
03-08-2005 18:08:15
I have a DC with a marvel shibler carb on it Ineeed to know what rebuild kit number it takes ThanksJT
Don L.
03-08-2005 18:33:05
 Re: DCTom or Don L Help in reply to Jerry Thomas , 03-08-2005 18:08:15
I believe you have a Marvel TSX616, used on 400 700 and 800.I have seen many a DC with this , but not listed in parts book. Correct kits are not available. BUT.... use what they provide, if the throttle shaft has to be replaced, using the new shaft, copy the old one. You will have to remove both ends and redrill the shaft to repin the ends accordingly. Did it some three years ago. Todays kit may fit??? LOL.
Don L.
caseman-d
03-09-2005 19:33:15
 Re: DCTom or Don L Help in reply to Don L., 03-08-2005 18:33:05
The marvel carb does show up in my parts book E221, serial 4511449-560000. It's the TSX-11 and you can still get certain parts from Case. You can get the bowl gasket, needle and seat, and I will have to run the carb to manifold gasket yet.
TSX-616 is used on the 400 series tractor. I was told once that some use the 400 carb on the D series because of a bigger venturi. The bowl gasket is the same as used on TSX-74.
TSX-616 was used on 400 1/55-12/57 and TSX-749 used from 1/58-12/59.
It appears the carb gasket, needle and seat, carb to manifold gaskets are the same for TSX-11 and TSX-616. I am showing different repair kits. I think the repair kit for the TSX-616 is still available from Case.
Don, are you getting your kits from Case or the auto parts store. I haven't had any complaints on the Case kits yet but we mostly sell just the bowl gasket, needle and seat and the carb to manifold gaskets. Can also get lot of the parts for the zenith carbs also. My email is open so if anyone has a questions just email me.
caseman-d
Jerry Thomas
03-09-2005 12:19:19
The carb tag is tsx146 it also has a 2b on the bowl next to the name.this is on a 1948 dc and it bolts right up to the cast aircleaner like the zeneths but it is a little bigger in size in the bowl area JT
caseman-d
03-09-2005 21:07:07
 Re: DCTom or Don L Help in reply to Jerry Thomas, 03-09-2005 12:19:19
Man o man i just have to many numbers in my head I can't read. Daaah TSX146.Talk about being blonde. Thats it, no more posts for a week, well maybe thats a little harsh, no more the rest of this week.
caseman-d
Don L
03-09-2005 15:15:37
That puts a hammer in the hammer mill [my Dad did that once]. Makes me think they used the correct bottom ,with some other large body marvel from another ap. CasemanD ..... what do you think? If you don't need the throttle shaft replaced, gaskets and float valve are no problem. Same as a U Minnie Mo and others. YT may have them for sale.
Don L.
caseman-d
03-08-2005 21:29:03
I want to disagree with you on that Don, D series did have the TSX-11, I will be checking numbers tomorrow on the kit's. Time to call it a night.
Tom
Don L.
03-09-2005 04:59:59
 Re: DCTom or Don L Help in reply to caseman-d, 03-08-2005 21:29:03
I see the tsx11 number in the carb kit section in aftermarket. Never knew what it fit
I can't find it in the A519 Case parts book for DC's after 5600000, which should be the last book. Interesting..... ..... ....
Don L.
