case what !! ??
not a case pro
03-08-2005 09:58:36
i recently found what i thought vac bwas a case but now that im looking at pictures and im not really sure could someone tell me how the case series works (i.e. va vac v vai ext) im familer with the farmall and case is probably something simple too thanks
Dale(MO)
03-08-2005 13:58:41
 Re: case what !! ?? in reply to not a case pro, 03-08-2005 09:58:36
The V had a flathead Continental engine; the VA had an overhead valve Case engine. The quickest way to tell by looking is the exhaust; the V is opposite the breather, on the right side (as you sit in the seat); the VA is on the same side (left) as the breather.
cant find
03-08-2005 20:30:53
 Re: case what !! ?? in reply to Dale(MO), 03-08-2005 13:58:41
have vic case but cannot find manuals for it im told its the same as a case f 14 can some one help
C. Amick
03-09-2005 08:32:17
 Re: case what !! ?? in reply to cant find, 03-08-2005 20:30:53
The only company that made an F-14 was IH that I know of. Perhaps it is a VAC-14 or a VC? Is there no serial number tag on the dash?
C. Amick
03-08-2005 13:41:19
The VA series replaced the V series. The C designated Cultivator (VC and VAC), I -Industrial, O - Orchard, H - High Clearance, etc. There were also different numbered versions of the VAC such as VAC-14.
Gord
03-12-2005 08:50:40
 Re: case what !! ?? in reply to C. Amick, 03-08-2005 13:41:19
You might find the information your looking for on our website jicaseworld.com
Don Livingston
03-08-2005 10:51:34
Take time to find some casting numbers. If they start with VT, it is a V or VA series.
Don L.
