Fluids for 1951 DC-3 Trans and Hydraulic
Chris Hibbert
03-07-2005 10:40:27
Had to tear my DC-3 down because I had ice in the transmission case (good grief). Could someone tell me what is the proper viscosity and type of oil for the transmission and Hydraulic system? I realize these are two seperate systems but I need to know both.
Thanks in advace - you folks are a great resource!
Chris
Paul f
03-07-2005 12:41:36
 Re: Fluids for 1951 DC-3 Trans and Hydraulic in reply to Chris Hibbert, 03-07-2005 10:40:27
For the Trans manual calls for 90w..lots of people use 85-140 your call--10.5 gals
Hydraulic originally used 10w (30w above 80 degrees 5w in extreme cold) however in mid 50s redesigned clutch plates changed spec to Type A ATF (Dexron). I had to replace all the plates in my PTO when I got tractor so I use Dexron.
it takes about 10 quarts
Paul f
03-07-2005 12:45:48
 Comments were for live PTO in reply to Paul f, 03-07-2005 12:41:36
Just reread your post..don't know what hydraulic was recommended for prior to live PTO
Larry Martin
03-07-2005 14:15:55
 Re: Comments were for live PTO in reply to Paul f, 03-07-2005 12:45:48
30 weight non detergent oil.
