eagle hitch to 3 point conversion?
Amishbob
03-06-2005 20:31:31
I'd really like to buy the 400 case I ll\ooked at this week but am concerned about the fACT THE FELLOW ADVERTISED IT AS 3 POINT BUT IT HAS AN EAGLE HITCHcan I use regular 3 point attachments or will this be a problem ?he says eagle is better cause it wont flop around,any ideas??? Bob
case300
03-07-2005 05:33:50
 Re: eagle hitch to 3 point conversion? in reply to Amishbob, 03-06-2005 20:31:31
Let's be honest here, after all Case had to retreat to swinging draft arms also, with sway chains and blocks when non swinging arms were desirable. When you have a four or five ton tractor running along in a furrow and you live in an area with rocks, like I do, something had to give when your plow came in contact with a rock. that's why Case made their plows pivot and, or break away to minimize some of the damage. Also back in those days the 3 point hitches weren't all standardized as close as they are now and it was difficut to hook up to all makes of equipment. And never try to put swinging arms on your hitch without also making the lift arms pivot at the top. In most cases I liked the eagle hitch so overall it's not a liability. My two cents worth.
C. Amick
03-07-2005 05:20:33
Some implements will hook right up and some won't. The problem is usually the spacing of the pins on the implement is too far apart and the arms won't spread out far enough. You can sometimes turn one or both of the implement pins to the inside to get it hooked up. I had to do this on a bush hog to get it hooked up. Once you get used to it, you will find that the Eagle Hitch is quicker to hookup and unhook than a conventional 3-point hitch.
John Saeli
03-07-2005 04:25:13
Hey Bob: George is correct. The E-H is built around Cat 1 Standards, but it can also be used for CAT 2. Be sure to get the Original CASE Top Link. They are valuable.
george md
03-06-2005 21:43:41
Bob,
Once you try eagle hitch, you will never
want to go back to those silly swinging arms.
george
mj
03-08-2005 15:29:07
 Re: eagle hitch to 3 point conversion? in reply to george md, 03-06-2005 21:43:41
WRONG!
Amishbob
03-07-2005 06:38:15
I appreciate the info!Thanks I'm going to get the 400 a real nice running machine
