VAC questions
Richard G.
03-06-2005 14:37:30
Just got a 1951 VAC. What should the oil pressure be? Also, the belt pulley is missing and when I remove the pulley dust cover the shaft turns with no resistance. Does this mean there is no bevel gear on the other end of the shaft? I would like to put a pulley on it.
Thanks, Richard
Joe (Wa)
03-06-2005 15:44:59
 Re: VAC questions in reply to Richard G., 03-06-2005 14:37:30
Case service manual oil pressure 12-20 psi, oil at operating temp and engine running at full load rpm of 1425.
Joe
Jerry W
03-06-2005 15:34:07
My oil pressure usually runs less than 20 psi and has for years.
If you have the belt pulley that does NOT have the provision for the high pressure piston pump underneath then it is probably just disengaged. There will be a jam screw on the top of the housing that holds the inner sleeve - loosen this and the inner sleeve can be moved in/out to engage or disengage the bevel gear. Do not have the tractor running when doing this.
The pump belt pulley I do not believe has this option.
Jerry
Les...fortunate
03-06-2005 16:13:03
 Re: VAC questions in reply to Jerry W, 03-06-2005 15:34:07
Mine (a '52) runs right around 20, maybe 18 when warmed right up and idling.
I have a belt pulley on mine but have never used it. The Owner's Manual describes how to make it work.
If I ever need to have the use of a belt pulley, I'll use the SC.
Richard G.
03-06-2005 17:07:53
 Re: VAC questions in reply to Les...fortunate, 03-06-2005 16:13:03
Thanks for the replies. My oil pressure is 20 all the time, so I am glad to know that is normal.
My hydraulic pump is on the back of the governor and not on the pulley housing. If I can find a pulley, I will use it to pull my syrup mill and woodsaw.
I got the VAC for $600 and it has new rear tires and Eagle hitch and runs great.
Thanks, Richard
Les...fortunate
03-07-2005 05:08:42
 Re: VAC questions in reply to Richard G., 03-06-2005 17:07:53
I wouldn't mind having another VAC for that price. Nice little tractor. There was a VAI advertised in my Market Bulletin for $500. No details given. Hmmmm
Ken Reavis
03-07-2005 18:58:27
 Re: VAC questions in reply to Les...fortunate, 03-07-2005 05:08:42
I have a 1943 VAC And the horses puled rhe wiring off the plugs and dist. Need to know the firing order.
Joe (Wa)
03-07-2005 21:30:24
 Re: VAC questions in reply to Ken Reavis, 03-07-2005 18:58:27
Should be 1-3-4-2. Should be cast on the top of the cylinder head, manifold side. If nothing else buy 4 rubber bottle stoppers, put one in each spark plug hole and roll the engine with the starter or hand crank.
Joe
