vai generator mystery solved
jon holt
03-05-2005 20:39:44
Well, I finally woke up and figured out why this generator doesn"t work. It is the wrong one. I would guess that it is a gm generator by the number on it. It is 1100504 with L 10 7 below it. There is not tag as far as indicatiing it is a delco or autolite etc. Also the lower bracket which came with the generator(taken off of a VAC) was bent in to accomadate the shorter housing of this generator. So I went out and checked some of the VAs that I have and found one with what appears to be an old GM top alternator bracket cobbled together and made that one work. I took some pictures and was going to post them but I can"t get it to work. Well that is enough writing for now. Thanks to everyone for their input.
