case 541 HELP
tleik
03-03-2005 20:36:54
I am working with a model 541 serial no.8343294.
This tractor has the high, low tranny. Some basic info would be helpful. Year hp . The part I really need help with its current problem[s].
It has a loud whine in the tranny area,but quiets down when the clutch is in. How hard is it to get parts for these and what sources do you use? If I do go to the time and expense of repair how reliable [tough] are the drive trains in these tractors? Also have a whine in the p steering.Any suggestions would be appreciated. If I change fluid what does it take for fluid and how do I drain and flush the system?
Tom (Ks)
03-04-2005 17:47:32
 Re: case 541 HELP in reply to tleik, 03-03-2005 20:36:54
Looks like you have a 1968 model, has 43 HP. They have a loud 4th gear. For transmission parts, I would go to a Case dealer. Engine parts can be obtained about anywhere. You have a filter inside the power steering pump, just remove the cover and replace. Hydrulic oil for the power steering pump. If you wanted to flush the oil, you could remove the hoses from the cylinders and turn the steering wheel (wide front models) ENGINE OFF of course. At that time, you can jack up the axle and turn the wheels removing the oil from the cylinders too.
