Case 580 E Forward/Reverse Problem
Phil Davis
03-03-2005 13:35:33
While I was moving dirt with the 580 E a freind stopped by and I left the dackhoe running for about 15 minutes will we were talking. When I went back to work the backhoe would not move. I had left the transmission in gear, but had put the forward/reverse in nutral while we talked. I checked the linkage and it is still hooked up correctly. I have tryed every gear. When I put it in forward or reverse I can easily remove and put it in any gear, which is not normal. Any help will be much appriciated.
MDSKY
03-03-2005 14:22:57
 Re: Case 580 E Forward/Reverse Problem in reply to Phil Davis, 03-03-2005 13:35:33
A 580E generally has two electric neutral switches. On is at the top of the loader control stick.The other is on the floor by your feet. The floor switch sometimes gets stuck down by mud and such.Just pulling up on it can solve the problem.If not you can unplug the solenoid. It is the large cylinder on the left side of the power shuttle,where the shift linkage attaches.
