David Brown 995
dej(JED)
03-03-2005 09:34:13
I have a chance to get a David Brown 995.
It looks okay, but I don't know much about this model. Also teh guy says that the 3 point won't go up and down, but the rear hydraulics do work.
Any thoughts would be appreciated.
Eddie in Ky
03-04-2005 19:36:44
 Re: David Brown 995 in reply to dej(JED), 03-03-2005 09:34:13
I have an 885, aneighbor has a 995. Depending on the year and the lift system, it may be an easy fix, it may be a problem troubled system. The 995 is overall a good tractor. Mine is all beat up (it was rolled) but it all works just fine. Find out which lift system it has and ask Elmer(Case/DB Guru)what he thinks. If it's a mid 70's with the sigle 3 pt. control lever, it's probably an easy fix, my neighbor has had the implematic and says its had more than its fair share of problems.
Ryan -WI
03-03-2005 18:10:09
We have one on my grandparents farm. Tractor was just about perfect. Sipped fuel and comfortable to work with. I would get it.
used to be james
03-03-2005 15:03:36
Great little tractors. If it starts and runs good, and the price is right, buy it. The hydraulics are notorious for doing that because there are tiny passages in the 3 point control valve that get dirt in them etc. The pros are right here who can help you fix the 3 point hitch. The price is usually reasonable on the David Browns. If it's all beat up on the outside, don't buy it. If someone can't take care of the outside, they can't take care of the mechanics either. James
