grumpy i need advise 5223 case
benwhi
03-03-2005 07:12:03
you are correct there is four solenoids, i noted they are all powered at the same time ,is this right? I also noted that the wiring leading to the sigmatron board has got hot. does this board located on the powershift panel affect that? I sure would like to find a factory service manuel. Do you have any leads on one, I appriciate any help you can forward,thanks a million.
Grumpy
03-03-2005 19:33:26
 Re: grumpy i need advise 5223 case in reply to benwhi, 03-03-2005 07:12:03
It takes two clutches engaged to make tractor move. If you have more than that it will kill the motor. If you have all four powered then you probably have a bad circuit board. Stan
