vai generator
jon holt
03-02-2005 21:09:56
Well I was getting the front end of my VAI all back together, put my new belt on and pulled the generator up to bolt to the upper bracket and tighten down and the bracket hit on the generator body. I was wondering if anyone knew if there were different size generators or different brackets between the va series. The generator came off of a VAC donor tractor and if I remember correctly the bracket was the same so I didnt take it. I have some pictures and was going to upload them onto the stuck and troubled section but am having trouble doing so. I left my email open if anyone wants to see to help. Thanks in advance
jon holt
03-03-2005 14:30:11
 Re: vai generator in reply to jon holt, 03-02-2005 21:09:56
third party image
trying again
Joe (Wa)
03-03-2005 18:09:25
 Re: vai generator in reply to jon holt, 03-03-2005 14:30:11
third party image
Jon, there is no pix ID in the URL for the pix you are are trying to post. Kinda looks like you are trying to enter the URL from the properties of the subject line over there instead of opening the post and copying the properties of the pix.
When you go to the review page, if the pix isn't there it won't post, might as well back up and try something else.
Joe
jon holt
03-03-2005 13:57:10
i am trying to link my pics with this post this is my first time so bear with me
Arthur
03-03-2005 03:48:27
sounds like you've got the wrong size belt on there....Should be a 7/8X44.75? long....There are still availble through your local Case dealer...Good luck
jon holt
03-03-2005 08:39:58
 Re: vai generator in reply to Arthur, 03-03-2005 03:48:27
I did get the belt from the case dealer. the bracket hits no matter where you move it. I also finally got a picture to upload. It is in the help identify section. I will put some more on if I get time. Thanks
Joe (Wa)
03-03-2005 09:23:53
 Re: vai generator in reply to jon holt, 03-03-2005 08:39:58
What about the bottom bracket that the gen pivots on. Doesn't it angle down to mount the gen lower?
Joe
jon holt
03-03-2005 13:25:23
 Re: vai generator in reply to Joe (Wa), 03-03-2005 09:23:53
i took it off with the generator but that is a good idea, i will try it tonight. Thanks
