Parts
Robert Swearing
03-02-2005 15:28:01
I am trying to find parts haudralic parts for a vac agriculture tractor. Part number listed as retired by the dealer is VT 2993, VT 5463, and VT4918. Alos interested in suggestions for modifying the system to accept currently available parts.
Joe (Wa)
03-02-2005 17:41:10
 Re: Parts in reply to Robert Swearingen, 03-02-2005 15:28:01
Robert, VT2993 & VT5463 are the same in a different configeration for specific model tractor. VT5463 is for VAC-14 only, parts manual doesn't say what model VT2993 is for but probably all earlier model in VA series. I assume this has to do with the Vac-14 being low profile and all earlier models high profile. Anyway it is just 1/2" steel tubing for the after section of the hyd pump to control valve system
VT4918 is the fwd section also common 1/2" steel tubing.
System working pressure is 800-900 psi if relief valve is set right.
I would just buy the tubing and cut, bend it to suit.
Page F-I-T on this board, he just went through this type thing.
Joe
