LA Case
ozfarm
03-02-2005 14:05:38
having just become the proud owner of a LA Case
was wondering before i go and fill the cyl up with a magical formula that dissolves rust
doe sthe LA,use cast or alloy pistons?????
prev owners had left there pride and joy outside with the exh uncovered
ozfarm
03-05-2005 01:43:44
 Re: LA Case in reply to ozfarm, 03-02-2005 14:05:38
third party image
let see if i gotta picture
C. Amick
03-04-2005 12:53:51
Read the articles on freeing up stuck engines in the Article Archives on this web site. One guy uses a mixture of auto transmission fluid, kerosene, and Marvel Mystery oil. I've heard that Kroil and P.B. Blaster work good as well. Be careful not to bend the push rods by turning the engine over with stuck valves.
Marty K
03-03-2005 10:35:27
third party image
Ozfarm,
I've also just become the proud owner of a '52 LA on propane. Mine's in a bit better shape though. I'm going to try and attach a picture taken Monday when it was delivered. Good luck on getteing yours running. Stick with it and move slowly. Otherwise things break instead of breaking free. Heat is your best friend during disassembly of stuck parts. Be careful.
ozfarm
03-03-2005 16:41:06
 Re: LA Case in reply to Marty K, 03-03-2005 10:35:27
if one could enlightened in the art of picture posting
one would post a picture of my wee tractor
Mike's600
03-03-2005 16:18:09
That tractor looks very familiar.She looks good in that Tx. sun.
ozfarm
03-03-2005 15:01:34
nice tractor
Pawn
03-02-2005 19:59:34
Originals are cast overbores are aluminum.
dctom
03-02-2005 17:43:23
ozfarm, i use hydralic pressure to break loose a engine, make sure all valves are closed and find the piston that is up and pump oil from another tractor, i always used my case D with about 1200 # of pressure, broke loose a lot of em and never hurt anything just my .02 tom
mike's600
03-02-2005 16:18:50
I use dsl fuel, or autotrans fuild. Let it sit a few weeks.
ozfarm
03-02-2005 16:42:34
 Re: LA Case in reply to mike's600, 03-02-2005 16:18:50
was thinking about citric acid
hence the concern about alloy or cast pistons
saw what a molasses bath did to a alloy Chamberlain 55DA piston:(
