parts avail for Case 400
Amishbob
03-02-2005 09:02:34
I think I've decided to buy a 400 but as I'm trying to see if some common parts are available I dont see alot listed for just a 400 alot seem to be available for 411 430 and so on is this the same as 400 gas is 2000.00 a good price for a decent running 400?? Thanks
c hess
03-04-2005 14:22:51
 Re: parts avail for Case 400 in reply to Amishbob, 03-02-2005 09:02:34
Read all messages an i am not sure of 400 you are looking at??? First or large on would have 38in tires- other or later small 400 would have 26in tires. Large 400 would easly pull plow you are talking about.
C. Amick
03-04-2005 13:04:19
Sounds like you are looking at the big 400 "series" with the 250 plus cubic inch engine? The other later 400 "series" has a 148 cubic inch engine. See if you can find the actual model number (4??) on the serial number tag. Might want to email Don L. and check with him on parts availablity at ([email protected]).
jeffw
03-02-2005 10:42:11
what area or state are you in
Amishbob
03-02-2005 11:57:24
 Re: parts avail for Case 400 in reply to jeffw , 03-02-2005 10:42:11
It is a 400 gas with wide front ,3 point ,power steering remotes
Amishbob
03-02-2005 11:40:33
I'm in north central Minnesota.
xiafarmkid
03-02-2005 13:41:00
 Re: parts avail for Case 400 in reply to Amishbob, 03-02-2005 11:40:33
A case 400 was built from 1955 til 1957. The 400 gas motored tractor is a 411, the deisel is a 401 and so forth. In 1958 it became a 400B series tractor. That is a totally different animal. The 400 gas (411) taht you are talking about is actually fairly common. Most parts are still available thru Case. Other than the engine itself, it is completely identical to the deisel version.
Amishbob
03-02-2005 16:07:03
 Re: parts avail for Case 400 in reply to xiafarmkid, 03-02-2005 13:41:00
Thanks for the info,I like those old cases my SC is ready for an overhaul I think this 400 will be great for my tiller and plowing and brush hogging I'm pretty handy but dont have much money so I hate to get into something I cant afford to keep running would like a bigger unit with a cab for these northern Minnesota winters but thats out of my budget unless I won the lottery!
leland
03-02-2005 22:08:46
 Re: parts avail for Case 400 in reply to Amishbob, 03-02-2005 16:07:03
Remember BOB a 400 has a egale hitch and a lot of 3pt implements will need to be modifed to work as my FIL found out.
gator63
03-04-2005 04:51:44
 Re: parts avail for Case 400 in reply to leland, 03-02-2005 22:08:46
What is the 400 (411) rated for HP?
Amishbob
03-04-2005 08:01:32
 Re: parts avail for Case 400 in reply to gator63, 03-04-2005 04:51:44
Thanks to Scott Ky! 53.25 belt and 44.89 drawbar ,would that pull a 3-14 bottom plow ??
ofbDave
03-04-2005 14:32:58
 Re: parts avail for Case 400 in reply to Amishbob, 03-04-2005 08:01:32
We pulled 4-14 plow in soil with a lot of clay with no problem, usually in 5th gear unless it was on much of a hill.
