powershift 2394 need advice
benwhi
03-02-2005 05:32:08
having trouble with power shift. when i put into reverse and release the clutch it sounds like engine binds up and shuts down. Can anyone give me advise what to look for or what to fix it
Jean C marleau
03-03-2005 18:53:46
 Re: powershift 2394 need advice in reply to benwhi, 03-02-2005 05:32:08
I do have a service manual for this 2394 my e mail is [email protected]
case trader
03-03-2005 18:04:27
there's a spool behind each solenoid i remove each solenoid to clean ,keep them in order, no they should not all be hot at the same time if you have a i& t manual page 53 in mine shows which clutch is applied such as low is c1 &c2 clutch pack the printed circuit board in the 96 series are prone to crack i suppose the 94 is the same around 120$.do the easy stuff first.
benwhi
03-08-2005 17:34:36
 Re: powershift 2394 need advice in reply to case trader, 03-03-2005 18:04:27
casetrader,i got a manuel and checked solenoids and activations and they were good as well as linkage adjustments.i replaced the board and now the engine binds up as soon as it cranks, i hit a nerve somewhere.before if you had the fuse out,it would pull forward gears. can you call me collect? any info would be greatly appriciated, thanks! 318-322-8080 Bennie
Grumpy
03-03-2005 05:09:07
94 series tractors do not use pilot spools. They use electric solenoids to control the powershift. You will need to put pressure gage on each clutch to determine if it is a contol problem. If al pressures are correct at the right time then the tractor will have to be split overhaul the powershift Stan
benwi
03-03-2005 06:59:16
 Re: powershift 2394 need advice in reply to Grumpy, 03-03-2005 05:09:07
Grumpy, you are correct, there is four solenoids. I also noted that all four of these is hot or powered at the same time.Are they supposed to be?Also i noted wires leading to the sigmatron board on the powershift panel has got hot. Does this electric or computor board control that? I appriciate any help you can forward.I sure would like to get a factory manuel on this.Do you have any leads on one? Thanks a million!!!
case trader
03-02-2005 18:24:56
do not force it everyone wants to rev the motor then tear out the clutch pack you need to clean the spools in the valve body i like to take them out chuck them in my cordless drill an use fine emery.
Can't even use my name
03-02-2005 19:03:43
 Re: powershift 2394 need advice in reply to case trader, 03-02-2005 18:24:56
I second that!
