SC Flywheel
REO
03-01-2005 22:10:49
I am overhauling a SC case and have run into a problem. I wasn't thinking when I took the flywheel off. I should have marked the flywheel and crank so I knew which way to bolt it back up.
Is there supposed to be marks on Flywheel to line it back up? Are any bolts offset so it can only go on one way? If not how do I go about bolting it up correctly? Both have been sent out to be machined so I don't have them in front of me right now to look at.
Any Help woul be great, Thanks
l.lAMP
03-02-2005 20:21:48
 Re: SC Flywheel in reply to REO, 03-01-2005 22:10:49
If you can get it bolted on wrong, you will be the first to ever do such a thing. The bolt spacing is such that you cannot put it on at all unless it is in the correct position. There is no guessing to it.
CATFISH
03-02-2005 14:25:09
I HAVEN'T HAD A SC APART LATELY, BUT IT SHOULD BE THE SAME AS A DC. THE BOLT SPACING IS DIFFERENT BETWEEN TWO BOLTS,SO IT SHOULD ONLY GO ON IN ONE POSITION. THE TIMING MARK IS AN "O" ON THE FLYWHEEL,AT TOP DEAD CENTER ON THE COMPRESSION STROKE, IT SHOULD BE VISSABLE THREW THE PLUG HOLE ON THE RIGHT SIDE OF THE TRACTOR. GOOD LUCK!!
C. Amick
03-02-2005 13:56:00
First I would like to say that I am no expert, but since no one else has responded to your question I thought I would give you my 2 cents worth. I've always tried to mark the flywheel and crankshaft before I remove them. I don't think there is any sort of mark on them? I don't think I have ever tried to put one back on at a different location from the way it came off so I don't know if it's possible to rotate it or not. Ask someone at the machine shop but this is a low RPM engine (1,600 rpm) and I don't think you will have problems if you put it back on at a different orientation. I do know that you must put the main bearing caps back on exactly the way they came off, because the journals are line bored and the rod bearing caps face toward the camshaft.
