case-o-matic hydraulic problems
mike1220
01-10-2006 19:04:01
I have a 630 Case-O-Matic and am having trouble with the Eagle Hitch. I add fluid to the resevoir at the filter but I can not get it to registor on the dip stick, and the lift will only work for one stroke. At the same time the fluid level in the transmission rises as I add more fluid to the Hydraulic system. If anyone has any suggestions I would appreciate the help.
K-Mo
01-11-2006 11:45:38
 Re: case-o-matic hydraulic problems in reply to mike1220, 01-10-2006 19:04:01
For Reference: The hydraulic/Case-O-Matic and the transaxle assembly are separate. The hydraulic/Case-O-Matic fill plug is on the bell housing near the engine and the dipstick is near the middle of the tractor on the right side. Transaxle filler plug/dipstick is on the top of the the transaxle assembly. It sounds like your hitch cylinder is bad. When you activate the hitch, the fluid leaks past the cylinder and into the transaxle assembly. When you get the hitch up, does it stay up or drift back down? This would be an indication of a bad cylnder. If the hitch stays up, then it could be the seal between the two resevoirs.
K-Mo
mike1220
01-11-2006 21:11:03
 Re: case-o-matic hydraulic problems in reply to K-Mo, 01-11-2006 11:45:38
K-Mo,
When I raise the hitch it will come down slowly, but I have also had it stay up as well.
