CASEOMATIC
Bob in MI
03-01-2005 12:31:51
I have a 630 caseomatic that grinds going into gear, even at very low idle. I can have tractor shut off, put in gear and start tractor, and will work fine. Do not like haveing to shut tractor off to change gears not to mention any safty issues. Thanks for your help.
G.B.
03-05-2005 19:51:10
 Re: CASEOMATIC in reply to Bob in MI, 03-01-2005 12:31:51
Bob, with my 530Ck I find that if I disengage foward-reverse lever I can shift into any gear with no grinding. Then I engage either foward or reverse, but solidly with a quick motion.
John Saeli
03-01-2005 16:15:52
Hey Bob: That's a common complaint with the C-O-M. The driving discs in there get warped with use, and drag. The wrong oil could aggrevate the situation. Dexron was recommonded, but Hytran seems to be OK. I start mine in gear, & when I change gears I don't spend much time in Neutral. I recently overhauled the converter in my 800 & it doesn't drag a bit.
Bob in MI
03-01-2005 18:38:26
 Re: CASEOMATIC in reply to John Saeli, 03-01-2005 16:15:52
Have you had your PTO unit apart, mine does not work. I like the COM and it works fine. The dealer does not offer much for parts for the 630's, not many were sold I guess. Any other places for parts that you know of? Thanks, Bob.
John Saeli
03-02-2005 17:39:08
 Re: CASEOMATIC in reply to Bob in MI, 03-01-2005 18:38:26
Hey Bob: I supply parts. What do you need?
