DC rod bearing inserts
Camboted
03-01-2005 05:04:01
A couple of weeks ago someone posted that they had a DC with factory rod bearing inserts. I never heard if that was verified. Anyway, we managed to find a Hino Diesel V8 from Japan that has a bearing insert we can adapt to the DC. We turn the crank just enough to get a mirror finish and then match the bearings, grind in the notch to hold the inserts, and it even has the oil grove. It makes a very smooth turning crank and costs us about $8 per rod, a lot cheaper than babbit. We also found a valve guide we can replace the original with that comes complete with a seal. We've got one engine completed with these improvements and we are anxious to test it under load. Just thought you'd like to know it can be done.
AllanC
03-01-2005 21:12:17
 Re: DC rod bearing inserts in reply to Camboted, 03-01-2005 05:04:01
Sounds like a good fix. I've never done it with a tractor but have seen the old chevy 216 done with shells. Easier than finding someone to do it here in wastern Canada. Cheaper also I think.
