VAC Project: Need some updated P/N's
F-I-T
02-28-2005 17:08:48
Hi:
I blew the seal on the front mounted Eagle hitch pump, so now it fills the engine crankcase with hydraulic oil. Not good.
I need a new part number for that seal. I have O4244-AB. I'll need to replace the film gasket that I replaced last fall (when I did not replace the seal...) which is V-20403.
Also could use the paper gasket number VT-3691. That goes between the block and the pump.
Thanks in advance.
Frank
F-I-T...parts ordered
03-01-2005 16:30:32
 Re: VAC Project: Need some updated P/N's in reply to F-I-T, 02-28-2005 17:08:48
Thanks a bunch guys! I have the parts ordered, so we'll report back when I have them installed.\
I'm anxious to see how it handles that little 2-14" Eagle hitch plow!
Frank
Augie
02-28-2005 21:45:14
This won't be any help on your current issue, but I've got a solution for the NLA double-lipped seal at the front of the transmission mainshaft.
Stack a pair of CR14256 or CR11800.
I've had real good luck coming up with seals at the local NAPA store. All they need to know to come up with a seal that will work is the ID (shaft size), OD (housing size), fluid type and working pressure.
Keith-OR
02-28-2005 20:22:27
Hey Frank, I have a invoice sitting here in front of me with the Case pump seal number, since I just replaced the seal and bearing in my pump. The number I have for the seal is # G105700. I got it from Case-IH dealer here. HTH Keith
Joe (Wa)
02-28-2005 20:35:15
 Re: VAC Project: Need some updated P/N's in reply to Keith-OR, 02-28-2005 20:22:27
Yeah that looks right Keith.
O4244AB > A26778 > G105700
V20403 > A30760
VT3691 > A30042
Joe
george md
02-28-2005 17:36:36
Frank,
For some strange reason , that one has a zero for that first digit. Translates to a national # 450009
did you get your package?
george
F-I-T
02-28-2005 17:59:31
 Re: VAC Project: Need some updated P/N's in reply to george md, 02-28-2005 17:36:36
George:
Yes I did. Thanks agian. I sent you an email, but perhaps I typoed the address. That was helpful on getting these numbers.
I unloaded the plow from a truck using my boom pole, but minutes later the seal had given way.
Oh well!
