Rookie Question about Case
John in Ne.
02-28-2005 15:32:27
What is the differencebetween a "D" and a "DC" Case tractor?I can find operators manuals on eBay for a "D" Case,But I haven't found any for a "DC". I am from Nebraska,and the "N" on our helmets stands for Nowledge,but for the life of me I can't figure this one out.Thanks John.
Glenn F.
02-28-2005 17:35:32
 Re: Rookie Question about Case in reply to John in Ne., 02-28-2005 15:32:27
I always wondered what that N stood for. Oh, and just for the record, the W on the Wisconsin helmet stands for "wisdom".
Paul f
02-28-2005 17:24:12
As other indicate any D manual will cover all D series models...more important is the serial number (age)... an early D series operators manual will not address the Eagle Hitch, Live PTO, Hydraulics found on later models...Conversly the Eagle hitch vintage manuals won't help you with motor lifts....
dbb62
02-28-2005 15:46:48
D is the standard tread tractor. DC is a variation of the same tractor. Most common is tricycle front. Lots of guys on here can answer specific questions.
The manual for D series will have pages for all D tractors, meaning D, DC, DO, DC3, DC4, etc. so should be what you need. I recently bought a parts manual for a D, and includes pages for all of the above when the parts do not interchange.
Larry Martin
02-28-2005 15:46:21
The D is a standard tread tractor and the DC is the row crop. Both tractors are in the same manual if it is a Case manual.
Camboted
02-28-2005 15:45:35
The DC has an adjustable rear axel and 38" rear tires, they came with an assortment of front ends, the DC-4 looking almost like a D, as they used the same fixed front axel. The D had fixed rear axels and, I believe, 30" rear rubber. They also had different rear sprockets, due to the smaller tire diameter.
John in Ne.
02-28-2005 18:29:28
 Re: Rookie Question about Case in reply to Camboted, 02-28-2005 15:45:35
Thanks for your replies,now I can get looking for a manual.John
