Case 430 Oil Pan
scotts-repair
02-28-2005 10:09:15
Hi, just ought a case 430 and need to drop the oil pan, looks like I have to drop the front axle. If I take off the 4 bolts holding the steering sector and front axle will it just drop off and then go back on, or is there more to it.
It seems that they woudl have designed the tractor with another 1" clearance to let you pull the pan without going to all this effort.
Tom (Ks)
02-28-2005 18:32:18
 Re: Case 430 Oil Pan in reply to scotts-repair, 02-28-2005 10:09:15
They used several front axles on these tractors, but they are mounted about the same. You are correct, take out the front bolts and the rear support. I assume you have a wide front. If you have a narrow front, can you just drop off the tires? (never have been around a narrow front to know how much clearance there is)
