Late Winter in Montana
Tom Railsback
02-28-2005 06:12:06
Saturday the themperature was around 50 so I decided to start my 1930 C which hasn't run since October 2003. When I first engaed the crank, it would not turn. Luckily, my IH friend was there and he figured out that the crank was binding up in its sleeve. Once we got that problem taken care of, things went well. Oh, I had to hold my mouth a certain way and use a few well chosen words, but that's normal with this tractor. It
took about 6 pulls on the crank after 2 pulls with the choke on. Then I had to start the DC4 and the S so I could get the C out of the shed. (Boy, does the DC4 ever have compression.) Once I got the C outside, it was time for a little trip around the pasture and yard and it ran beautifully, just like it had been run every day instead of sitting with a shed roof down on it for almost a year. All I have to do to get it ready for the St. Patrick's Day parade is to wash it and put in a little more gas.
After that little ride, I took the S out for a longer one. More later.
Scott KY
02-28-2005 16:16:42
 Re: Late Winter in Montana in reply to Tom Railsback, 02-28-2005 06:12:06
Sounds like you had a good day. It was about 50 degrees here in Kentucky so I test drove my 1950 VAC that I had replaced the transmission in. The transmission was quiet has a new one. I was very pleased. Also got to drive the foot clutch SC I just bought. Boy it is a sweet tractor. Has original paint and tires. A one owner tractor! Did you get my check for the DC parts?
Tom Railsback
02-28-2005 20:04:11
 Re: Late Winter in Montana in reply to Scott KY, 02-28-2005 16:16:42
Scott:
I got your check. All I need to do now is get everything packed up and off to you.
dctom
02-28-2005 06:51:50
WAY TO GO TOMMY; DCTOM
