dctom build numbers?
Nickolas
02-26-2005 21:04:52
Hi Tom, Just purchased a old Case tractor here in San Diego, CA. Serial number 5256931 VAO, any Info would be great!
What is the best way to determine if the system is 6 volt or 12 volt? There is no battery.
Thanks
dctom
02-27-2005 08:47:00
 Re: dctom build numbers? in reply to Nickolas, 02-26-2005 21:04:52
have no cards for rock island built units, e mail ([email protected] he can send you a copy if he has it, lots of them are lost tom
Jerry W
02-27-2005 06:44:08
It is a 1948 (first 2 digits of the serial number - 4) orchard variety of the VA Case. Great little tractor. It will probably have a non adjustable wide front and 24 or 28 inch rear rubber. Might have originally have had a lot of skirting to protect the essentials of the tractor but over time usually got removed and scrapped.
Originally was 6v positive ground but many have been converted to 12v negative ground. Usually the voltage and ground polarity can be found from the regulator which is usually marked.
Jerry
