How to free my C engine
R Wyler
02-26-2005 18:36:33
Tonight I pulled the head off my C I was pleased to see the cyls are in good shape with only mild rust they look like that may be okay after honeing them out provided I can free the pistons up in them. What should I pour into the cyls to soak them in? WD 40? diesel? Thanks for any help.
farmerKen
03-24-2005 09:05:06
 Re: How to free my C engine in reply to R Wyler, 02-26-2005 18:36:33
I got mine free by using penetrating fluids and diesel fuel.If you are not in a hurry let it soak in for a while,then get back to it in a week or so.I was able to free mine up without tearing it down completely.Hone out on top of pistons so when the other pistons do travel up they are running in a rust free area. I did have to hit on top of the piston with a block of wood but it did start to move.Good luck! If you know where I can find a belt pulley for my "C" Case please let me know
R Wyler
03-24-2005 16:28:24
 Re: How to free my C engine in reply to farmerKen, 03-24-2005 09:05:06
Thanks for the info Ken I may try that pretty soon. It would be neat if I could get it loose without a tear down. Are belt pulley's hard to find? If I find one I will let you know.
kscher
03-05-2005 19:57:46
If Kroil doesn't work put in a few inches of diesel & set it on fire. This will expand the sleeve & thin the diesel. Of course you need to remove the gas tank & have the tractor outside if you try this.
Casenut
02-27-2005 12:12:50
I have tried a new product the last one I did. It is called Deepcreep made by Seafoam. seems to work very well. My 2 cents worth. Casenut
C. Amick
02-27-2005 11:49:51
I think you will want to try to free it up with the head on it. You may push the sleeves up while trying to free the pistons. If you are going to remove the sleeves anyway, it may not matter. There are some good articles in the Article Archives on freeing stuck engines on this web site. One guy used auto trans fluid, kerosene and Marvel Mystery oil mixed together.
thejdman01
02-27-2005 11:20:40
kanolabs.com kroil is the best stuff and guarenteed works super well. also mix that with some mystery oil works well
thejdman01
02-27-2005 11:20:35
thejdman01
02-27-2005 11:20:00
190xtd
02-27-2005 08:41:52
I have had good luck using atf. I would fill the cylinders up and check every few days.
DKase
02-26-2005 21:32:18
From my experience all the soaking in the world makes little difference. You might as well just get to it! Pull the engine, pull the pan, pull the timing cover, pull the crankshaft, knock the pistons out the bottom one at a time and if they are salvageable you will not have any trouble getting them out. If they don't come out they are shot anyway. Good luck DK
Gene Dotson
02-26-2005 20:41:17
I have had good luck with Coca-Cola. Worked on My Vaiw, VA and VAC.... Gene
Camboted
02-27-2005 06:23:26
 Re: How to free my C engine in reply to Gene Dotson, 02-26-2005 20:41:17
Nothing against Coke, but I think I'd vote with DCase. The problem is your rings are probably set up as well. Even if you should free up the pistons, you won't get a good hone with them in the cylinder so, bite the bullet, pull (or rather knock them) out, and hone, and re-ring the pistins. You will be happier in the long run, unless, all you want to do is run it for a few days per year, then try the Coke. Anybody drink Pepsi??
Gene Dotson
02-28-2005 11:13:27
 Re: How to free my C engine in reply to Camboted, 02-27-2005 06:23:26
Hey Ted; I drink Pepsi. The acid in the Coke works on the rust and Pepsi doesn't have that. The VAI and VA rings were both stuck in the ring lands so tight that I had to break them and drive them out with a small punch. The pistons and cylinders were both usable with a through honing and new rings. Both are running fine now. It is my belief that any engine that is stuck hard enough to require any type of soaking will need at least new rings. One would be very fortunate to have a good running engine without pulling it down for rings... Gene
