Csae 51 SC Manifold Question
DWhittemore
02-26-2005 02:48:41
I have a 51 case sc with full gas manifold the flap inside the manifold is rusted away I will need a new one,but,can I make a change to a gas manifold? (2) where can I get gas manifold? if I can make change. Thanks Dennis fla.
C. Amick
02-27-2005 11:58:31
 Re: Csae 51 SC Manifold Question in reply to DWhittemore, 02-26-2005 02:48:41
Are you talking about the dual fuel manifold with the lever on the outside? If so, didn't know Case was still making dual fuel manifolds in 1951. Yes, you can switch to a gas manifold. There are cast iron inserts in the head that have to be removed to use the gas manifold, but that's all that you have to change.
bob schooley
07-10-2006 18:25:35
 manifold for 611b in reply to C. Amick, 02-27-2005 11:58:31
does anyone know where a person could locate a replacement manifold for a 611b part #g2009 or g 2025 thanks
DWhittemore
02-27-2005 17:06:28
 Re: Csae 51 SC Manifold Question in reply to C. Amick, 02-27-2005 11:58:31
Mr.amick,if I remove the two cast iron thingys from the head ,do I have to insert ferrule where I removed the thingys, or can I just bolt right to the head..(the thingys Im talking about could be called venture ...)sorry dont know what the part name is.but I would still the same elbow,right.? Thanks Dennis
C. Amick
02-28-2005 07:15:48
 Re: Csae 51 SC Manifold Question in reply to DWhittemore, 02-27-2005 17:06:28
There should be some thin steel rings that are used to keep the manifold centered. They fit between the manifold and head. They are about 1/2-inch long and look like they were cut from a piece of exhaust pipe. There are indentations in the manifold casting for them to sit in. Other than a gasket, this is all you need.
DWhittemore
02-26-2005 11:33:35
George, Thanks for your reply,on the manifold,my E-mail is:[email protected]
george md
02-26-2005 20:23:12
 Re: Csae 51 SC Manifold Question in reply to DWhittemore, 02-26-2005 11:33:35
Dennis,
I send the mail , did you get it ?
george
DWhittemore
02-27-2005 02:13:38
 Re: Csae 51 SC Manifold Question in reply to george md, 02-26-2005 20:23:12
Hey George, Did not get your mail yet.... E-Mail [email protected] Dennis
george md
02-26-2005 10:35:52
Dennis, I assume you mean a dual fuel manifold . I can fix (replace ) the valve (baffle, damper, or whatever you would like to call it ). I have one here now that I am repairing ,manifold is in good condition but the damper and cover were well rusted .Cover broken and with holes but repairable, damper in pieces and rusted beyond repair. Cover is repaired and damper is almost done. Post an email and I'll send you some pictures.
george
