case sc
jbug
02-25-2005 14:20:47
I bought an sc that someone had messed with the points and rotor. It appears to me that the timing is set off of the rotor with a set srew is this correct? If so how do you find the proper time once it is out? Also, I have had a very difficult time trying to find a new rotor, are they still available? Finally, the tractor has a 3-pt type hitch, but instead of swing arms it has a solid u-shaped bracket that goes up and down. Was this stock or is this something that has been added on? Or should I just break down and buy a manual, HaHa???? Any help would really be appreciated.
C. Amick
02-25-2005 17:51:02
 Re: case sc in reply to jbug, 02-25-2005 14:20:47
Never seen a rotor with a set screw in it. I think someone may have adapted the wrong rotor to the wrong distributor. The tractor originally came with a magneto. If the cap sits vertical, it's probably a Delco distributor. If the cap sits horizontal, it's probably an International Harvester distributor. If you have either of these, new rotors and caps should be available at your local auto parts store. The Delco distributor fits an AC WD-45 and the IH distibutor fits Farmall Cub, Super A, Super C, etc. Spark plug needs to fire when No. 1 cylinder (front) is about 1/2-inch before top dead center. The "U" shaped thing on the rear is stock. It is a lifting bail. It was made before the 3-pt hitch came along. I think they have a manual for sale on this site, but first we need to figure out what year the tractor is.
Paulf
02-25-2005 16:45:20
Points and rotor??? Do you have a magneto or a replacement system. What is serial number??? Manual ..yes but make sure you get one that is appropriate for the vintage of your tractor...depends on Serial #
