carb rebuild 411b bob, caseman,casepoor pg.2
GARY CASE
02-24-2005 14:10:50
go to pg. 2
BobV
02-26-2005 09:38:29
 Re: carb rebuild 411b bob, caseman,casepoor pg.2 in reply to GARY CASE, 02-24-2005 14:10:50
Carb. # I checked caseman-d yes it is G45719, could it have come from another tractor ? I wouldn't know, thats what was on the tractor when I bought it.
case poor i n pa
02-26-2005 05:45:43
wow all these numbers and letters...i think im doing chinese arithmatic..easier to ask don....
BobV
02-25-2005 14:03:13
GARY CASE Just a follow up I'm also looking for a kit but the carb. is a Zenith #G45719,12255, I've a Case,IH parts dealer hear in NC looking for me and if I have success I'll let you know.
caseman-d
02-26-2005 18:14:22
 Re: carb rebuild 411b bob, caseman,casepoor pg.2 in reply to BobV, 02-25-2005 14:03:13
Bob,
I found that carb listed under the 500B/600B listing. Group G45719 zenith model 62AJ10/Outline #12255.
carb to manifold gasket Part # G46826 subs to 1342824C1.
bowl gasket c142-15 subs to B51462, may change.
needle and seat, c81-1-45 subs to B51345.
Repair kit, B51566.
These numbers may sub again but most any Case dealer should be able to update them. I will try to check them next week.
caseman-d
caseman-d
02-25-2005 17:40:44
Bob,
Are you sure on the numbers. I was looking today at the zeniths carbs and I didn't see anything with G45719, I did find a zenith carb with outline 12255. I forgot to bring the information home. I will try to get back out to work tomorrow to get the copies I made. If you have the zenith part numbers then I can cross them
Please note part number G46826 changes to a 1342824C1 from previous post.
caseman-d
Joe (Wa)
02-25-2005 19:35:11
 Re: carb rebuild 411b bob, caseman,casepoor pg.2 in reply to caseman-d, 02-25-2005 17:40:44
I can't find G45719 in any of my Case stuff either but apparently it is or was a good nr.
G45162 12329 & G45719 12255 are listed @ the link as used (among others) on CC,D,DC,DT,DO,DST,D2,400,510,510B
Joe
gary case
02-26-2005 13:03:39
 Re: carb rebuild 411b bob, caseman,casepoor pg.2 in reply to Joe (Wa), 02-25-2005 19:35:11
G45162 CARB-ZENITH MODEOL 62AJ10-OUTLINE #12329 400BSERIES. THIS IS FOR THE 300B AND 400B SERIES ALSO ACCORDING TO THIS BOOK.
caseman-d
02-25-2005 11:31:21
Gasket carb to manifold..... G46826
bowl gasket ..... B51704
needle/seat ..... .A30244
repair kit..... ....A43644
marvel tsx-749 carb
Will check these numbers to see if there still good.
caseman-d
I show a zenith 62AJ10 no, 12329 for the 400.
caseman-d
caseman-d
02-24-2005 20:29:23
Gary,
I don't have a parts book at home so I will have to see what I can find at work. caseman-d
